Does IE 8 still supported by web browsing?
Discussion in 'Windows XP Networking' started by rustedmetal, Mar 8, 2021.
  1. rustedmetal
    rustedmetal
    The PC (Toshiba Satellite 5205-S503 with XP Home Edition SP3(i got from a fellow member on here)) i have doesn't not work with WiFi at the moment but it does connect through LAN. However even though it can bring up search results it won't go into individual web pages? Is this a a browser issue? I also installed the updates for IE 8.
  2. rustedmetal
    Elizabeth23, Mar 8, 2021
    Samir likes this.
  3. rustedmetal
    SaddamHussein
    SaddamHussein, Mar 8, 2021
  4. rustedmetal
    rustedmetal
    Works fine with Firefox. Thank you!!!
    Samir likes this.
  5. rustedmetal
  6. rustedmetal
    SaddamHussein
    The Github website has some TLS/SSL incompatibilites on XP x64-IE8 and throws this infamous "cannot display the webpage" error. ie8.png
    SaddamHussein, Mar 11, 2021
  7. rustedmetal
    do not use ie8 for anything but microsoft updates!!!
    Elizabeth23, Mar 11, 2021
    rustedmetal likes this.
  8. rustedmetal
    rustedmetal
    Yeah i've been using FireF Fox but how do i get the updates? I haven't seen the updates coming up or anything. I have the setting on "download but don't install".
    rustedmetal, Mar 12, 2021
  9. rustedmetal
    rustedmetal
    Yeah, i just used Firefox.
  10. rustedmetal
    go to start, all programs, it upper section on right side is a link to windows updates, click on this and if it asks to update to microsoft updates do that and then run a CUSTOM scan for updates, custom lets you choose which updates you want to install. and be aware that most updates have to be installed at shutdown and not at a restart.
    Elizabeth23, Mar 12, 2021
  11. rustedmetal
    rustedmetal
    Once i click on updates it goes though IE but since EI doesn't work then it's a dead end. Maybe Firefox can be used for the same process?
    rustedmetal, Mar 14, 2021
  12. rustedmetal
    not through firefox that I am aware of
    1. go to control panel/ internet options/security and reset all levels to default
    2. go to services and ensure that automatic updates, cryptographic service and background intelligence service are all set to automatic
    3. restart pc and then try the link in all programs again
    Elizabeth23, Mar 14, 2021
  13. rustedmetal
    rustedmetal
    IE still says "Internet Explorer cannot display the webpage"
    rustedmetal, Mar 15, 2021
  14. rustedmetal
    Elizabeth23, Mar 15, 2021
  15. rustedmetal
    rustedmetal
    Hey everyone. I've been very busy so i hadn't had the chance to participate in the forum for a while. But here i am...!!? o_O
    Ok, anyway. What is an alternative to get thse updates going if the site is not working? Maybe buy a Cd with the updates already on it? Seems to easy though.
    rustedmetal, Apr 11, 2021
  16. rustedmetal
    Samir
    HSV and SFO
    Anyone have the updates downloaded? Then we can just put them up on a server somewhere.
    Samir, Apr 11, 2021
  17. rustedmetal
    https://www.geeksinphoenix.com/blog...-and-install-windows-drivers-and-updates.aspx
    the updates are still available through the microsoft update catalog.
    I fortunately had all the updates downloaded through using portup, a program that updates your pc offline, after loading all the updates online first.
    a lengthy project.
    I could upload all of them that I have to my onedrive, but this could take forever as my isp only has approx 4mbps upload capabilities. :)
    Elizabeth23, Apr 11, 2021
    #17
  18. rustedmetal
    Samir
    HSV and SFO
    How big are all the updates? If they'll fit on a CD or DVD, I don't mind sending you some blanks that you can send back to me loaded. Then I'll have a copy that I can write and send out to anyone that needs them or upload to wetransfer. :)
    Samir, Apr 11, 2021
    #18
  19. rustedmetal
    red Guest
    yep got them from there the other day were 51 for xp all fit on a cd :)
    red, Apr 11, 2021
    #19
  20. rustedmetal
    samir, you might try to download one of the unofficial service pack 4's and then extract the files.
    or download portup and let it get the downloads for you, it will be particular to your pc as that is what it will search for, but then you can separate the uploads to the ones for everyone. my cache for portup is a couple of gb's large.
    http://www.portableupdate.com/
    after it is installed, let it search your pc and then download the updates, this is what I did at the beginning, and now when I do a reinstall, I just update from portup without going online.
    #20
