Customize Registry on ISO
Discussion in 'Windows XP Customization' started by Doku FREENET, Mar 7, 2021.
  1. Doku FREENET
    Doku FREENET
    Hello,
    i created an ISO off my Windows XP Professional Disc, so i can Customize it, for that , i need to Customize the Registry, so if i Install XP, i don't have to do that manually after the Installation Process. I don't know how and if this is Possible?Can anyone help?
  2. Doku FREENET
    if you use nlite to create your ISO you will be able to make many customizations
    Elizabeth23, Mar 8, 2021
  3. Doku FREENET
    Doku FREENET
    It cannot Edit The Registry in the needed Way, I need to Add a Registry Key, this can only customize some Settings, that's totally not what i need :-(
    Doku FREENET, Mar 8, 2021
  4. Doku FREENET
    then your best bet would be to install xp to your liking and then create an image on another drive.
  5. Doku FREENET
    Cesare Vesdani
    United Kingdom
    I never thought that it was possible to customize the registry editor files with an ISO CD. How do you do that? Did you install any third party software or drivers to make an ISO CD?
    Cesare Vesdani, Apr 14, 2021
  6. Doku FREENET
    esuhl
    I think I've done this before in nLite.
    If you create a .REG file listing the registry changes, and then add it via the "RunOnce" tab of the Unattended section in nLite... wouldn't that work...?
    esuhl, Apr 23, 2021
  7. Doku FREENET
    Cesare Vesdani
    United Kingdom
    I have heard on a YouTube video once that it is possible to slipstream all service packs and other updates such as .NET FrameWork updates to a Windows XP Professional .iso image file using Command Prompt.
    Cesare Vesdani, Apr 23, 2021
  8. Doku FREENET
    esuhl
    Probably easier to use nLite, though?
    I've used nLite to slipstream SP3, .NET v1.1 and .NET v3.5 (which is backwards compatible with v2.x), IE8, WMP11, and all subsequent hotfixes into an XP Pro ISO.
    esuhl, Apr 24, 2021
  9. Doku FREENET
    Samir
    HSV and SFO
    What I've done is set up xp how I like it, then imaged it using clonezilla and then can replicate that install to any system that will boot it. Usually the video driver is what will mess it up, but you can go into safe mode and fix that and then boot.
    Samir, May 3, 2021
    esuhl likes this.
