Corrupt XP Discs
Discussion in 'Windows XP Installation and Setup' started by Don MacNeill, Jan 8, 2014.
  1. Don MacNeill
    Don MacNeill
    I have upgraded my wife's and my XP to 7. I have a 3rd computer running XP but it is corrupt. The 2 old XP discs are corrupt so I can't repair it. How do I obtain replacement discs.
    I am also considering doing dual boots for XP and 7 in the 2 other computers so that I can run incompatible programs on XP (such as BackUp MyPC to recover backups)
  2. Don MacNeill
    Elizabeth23, Jan 8, 2014
  3. Don MacNeill
    Don MacNeill
    Thanks Elizabeth. I contacted Microsoft and find that XP is not supported and that I must purchase new retail discs (my original ones are retail and so I can't go back to a PC manufacturer. I build my own systems in any case.)
    Regarding the corruption, my disc gave this message when I tried to load it on a new computer years ago. I have been using my wife's since as I wipe and reinstall programs on hard drives or set up new computer equipment. It finally gave out. Perhaps it is scratched.
    Thanks for the info on the dual boot procedures
    Don MacNeill, Jan 9, 2014
  4. Don MacNeill
    Elizabeth23, Jan 9, 2014
  5. Don MacNeill
    if you download imgburn DO NOT install any of the offered software.!!!
  6. Don MacNeill
    Don MacNeill
    I have decided that it will be much easier to run Ubuntu on my separate computer. It seems to support the programs that 7 wouldn't but XP would.
    Don MacNeill, Jan 13, 2014
  7. Don MacNeill
    okey-dokey, :)
    Elizabeth23, Jan 13, 2014
  8. Don MacNeill
    fingerfood12345
    Are you sure the corruption you speak of is not caused by the optic-disk drive? I recently had somewhat of the same experience, and finally realized I had to replace my optic drive, and PRESTO!, no more problems....
    fingerfood12345, Mar 18, 2014
