Computer will not boot up.
Discussion in 'Windows XP Hardware' started by h18pdw, Oct 5, 2014.
  1. h18pdw
    h18pdw
    Hi I have windows xp home that is having trouble booting up.
    It tries to load and goes to windows screen, then a blue box flashes up then tries to restart all over again.
    I have picked up a recovery disk but when trying to run chkdsk it goes to 25% and says errors and the stops on the dos screen.
    I have loads of files I dong want to loose and also some photography things which I need back from it.
    Can anyone help me in either trying to get all my items onto an external hard drive which I hot or even try and get windows back up and running.
    I have tried safe mode which does not work either.
    Any help great fully received.
    I can supply pics of what the screen comes up with etc if needed.
    Very concerned I have lost my stuff so really could do with some help ASAP PLZ.
    Thank you in advance.
    h18pdw, Oct 5, 2014
  2. h18pdw
    if you want to see what the blue screen (bsod) says then you will have to get to the advanced boot menu on your pc and choose to Disable Automatic Restart, turn off pc and then turn on and start tapping F8 to get to the advanced boot screen then the blue screen will stay put and you can give the stop error codes and any files associated with the bsod.
    if checkdisk cannot finish it might be due to a failing hard drive and I will give you instructions to download and burn a copy of Hiren's boot cd, then using mini xp you will be able to get your data off the drive and download to a flash drive:
    Courtesy of Jose Ibarra
    http://www.imgburn.com/
    cmd
    chkdsk c: /r
    you can try chkdsk from hiren's or just get the data off
    Elizabeth23, Oct 5, 2014
  3. h18pdw
    Jojo
    Just a thought, but there was a virus doing the rounds about 10 years ago now that did exactly as you describe. I'm trying to recall the name.
    Anyway, it seems like a long shot but you could try booting into safe mode. (either press F8 or F5 at startup then select SAFE MODE no networking)
    then run :
    Rkill
    then Junkware Removal Tool (JRT),
    then ADW Cleaner.
    All those are available from Bleeping computer: http://www.bleepingcomputer.com/download/adwcleaner/
    JRT takes ages to run, if you have a large number of files, it can take up to 20 mins. But it is the best, so let it do its job.It will finish when it's done
    If you can, download and save these tools to a pen drive then reload from there, after you have booted to SAFE mode no networking
    Jojo, Oct 6, 2014
  4. h18pdw
    @Jojo, hi, I believe that the op said he could not get into safe mode either. :)
    Elizabeth23, Oct 6, 2014
  5. h18pdw
    Jojo
    Apologies.
    Jojo, Oct 13, 2014
