Computer Freezes Upon Plugging in USB device
Discussion in 'Windows XP Help and Support' started by Griffon2-6, Aug 5, 2013.
  1. Griffon2-6
    Griffon2-6
    Hi,
    I have a desktop that seems to have recently developed a problem with using USB devices. Whenever any USB device (with a few exceptions, I'll elaborate below) is plugged in while Windows is running, the computer would completely freeze and become unresponsive to all input, requiring a hard-reset to make it usable again. If a USB device is plugged in during boot, the boot process doesn't go any further than the scrolling Windows screen, after which it gets stuck on a black screen.
    This seems to happen for any USB drives, printers, and even my camera. The only devices which don't cause the computer to behave this way are my wireless USB mouse and keyboard receiver, as well as USB smart cards used for authentication for some Chinese banks.
    I've tried the following to no avail:
    1. Plug in a PS/2 keyboard to make sure that Windows was actually frozen, not just unable to read from the USB ports. Windows seems to actually be frozen.
    2. Boot into Ubuntu on the same machine from an Ubuntu installation DVD to make sure that the problem is specific to Windows. Ubuntu seems to have no problem using the USB ports with any device.
    3. Uninstall all drivers under the "USB" category in device manager and let Windows reinstall them.
    4. Disable the drivers for the Chinese bank smart cards.
    5. Ensure that all Windows Plug and Play services are set to automatically start at boot.
    6. Boot Windows in safe mode with command prompt and in diagnostic mode. When booting in this fashion, boot gets stuck after indicating that MUP.SYS is being loaded.
    I've read that MUP.SYS is rarely the problem when something like this occurs: it's merely the last driver to load, and after that Windows starts doing some things that it doesn't report.
    At this point, I've exhausted everything I can think of. Any help on this problem would be highly appreciated!
  2. Griffon2-6
    Griffon2-6
    I forgot to mention that the computer is running Windows XP Professional 32 bit. It has an ASUS P5SD2-X motherboard with a 3.0 GHz Pentium 4 processor.
    Griffon2-6, Aug 6, 2013
  3. Griffon2-6
    run checkdisk first, then we will do some other things:
    go to start, run, type in cmd
    type exit and press enter
    restart pc, allow checkdisk to finish and run again.
    this can be a lengthy process depending on the size of your harddrive, run as many times as it takes until no errors are found and fixed, report can be viewed in Event viewer
    go to start, run, type in eventvwr.msc, go to applications, then Winlogon.
    post back with results and we will go from there.
    1. what is your current antivirus?
    2. does device manager have any warnings?
    Elizabeth23, Aug 6, 2013
  4. Griffon2-6
    Griffon2-6
    Thanks, I'll give that a try.
    The computer is using Microsoft Security Essentials as its antivirus and Device Manager is not showing any warnings.
    Griffon2-6, Aug 9, 2013
  5. Griffon2-6
    okay, let me know the results of checkdisk.
    Elizabeth23, Aug 9, 2013
  6. Griffon2-6
    Griffon2-6
    Hi, sorry for the wait.
    I found three files under the winlogon folder in Event Viewer. I've enumerated each of them and pasted the contents below (had to edit the links in order to post). However, the dates recorded in each of these files seem to be off, in particular the last one which seems to be dated to before UNIX time. I ran chkdsk some time last week.
    1.
    Event Type: Information
    Event Source: Winlogon
    Event Category: None
    Event ID: 1001
    Date: 9/1/2012
    Time: 8:47:49 PM
    User: N/A
    Computer: GAMER
    Description:
    Checking file system on D:
    The type of the file system is NTFS.
    Volume label is House.
    One of your disks needs to be checked for consistency. You
    may cancel the disk check, but it is strongly recommended
    that you continue.
    Windows will now check the disk.
    Cleaning up 1 unused index entries from index $SII of file 0x9.
    Cleaning up 1 unused index entries from index $SDH of file 0x9.
    Cleaning up 1 unused security descriptors.
    CHKDSK is verifying Usn Journal...
    Usn Journal verification completed.
    48845600 KB total disk space.
    48117078 KB in 5379 files.
    9416 KB in 725 indexes.
    0 KB in bad sectors.
    124779 KB in use by the system.
    65536 KB occupied by the log file.
    594327 KB available on disk.
    512 bytes in each allocation unit.
    97691201 total allocation units on disk.
    1188655 allocation units available on disk.
    Internal Info:
    40 34 00 00 e4 17 00 00 39 26 00 00 00 00 00 00 @4......9&......
    57 0d 00 00 00 00 00 00 1a 00 00 00 00 00 00 00 W...............
    b6 28 8e 01 00 00 00 00 60 e8 00 07 00 00 00 00 .(......`.......
    f4 3c 82 01 00 00 00 00 00 00 00 00 00 00 00 00 .<..............
    00 00 00 00 00 00 00 00 22 f0 5a 15 00 00 00 00 ........".Z.....
    e0 80 d2 b2 00 00 00 00 b8 3c 07 00 03 15 00 00 .........<......
    00 00 00 00 00 58 d5 78 0b 00 00 00 d5 02 00 00 .....X.x........
    For more information, see Help and Support Center at hxxp://go.microsoft.com/fwlink/events.asp.
    2.
    Event ID: 1001
    Date: 9/1/2012
    Time: 9:34:01 PM
    User: N/A
    Computer: GAMER
    Description:
    that you continue.
    Internal Info:
    4a 5e 05 02 00 00 00 00 7e 6d 67 07 00 00 00 00 J^......~mg.....
    10 8b 90 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00 00 00 00 00 00 00 00 de 90 c0 16 00 00 00 00 ................
    b0 fd 65 78 00 00 00 00 b8 3c 07 00 03 15 00 00 ..ex.....<......
    that you continue.
    Windows has checked the file system and found no problems.
    48117081 KB in 5380 files.
    594324 KB available on disk.
    1188649 allocation units available on disk.
    Internal Info:
    40 34 00 00 e5 17 00 00 3a 26 00 00 00 00 00 00 @4......:&......
    57 0d 00 00 00 00 00 00 19 00 00 00 00 00 00 00 W...............
    8c b3 78 01 00 00 00 00 14 ad 05 07 00 00 00 00 ..x.............
    24 2a 6f 01 00 00 00 00 00 00 00 00 00 00 00 00 $*o.............
    00 00 00 00 00 00 00 00 c0 de 28 15 00 00 00 00 ..........(.....
    30 44 d3 b2 00 00 00 00 b8 3c 07 00 04 15 00 00 0D.......<......
    00 00 00 00 00 64 d5 78 0b 00 00 00 d5 02 00 00 .....d.x........
    Event ID: 1001
    Date: 9/1/2012
    Time: 9:34:01 PM
    User: N/A
    Computer: GAMER
    Description:
    that you continue.
    Internal Info:
    that you continue.
    Internal Info:
    3.
    Event ID: 1001
    Date: 12/31/1969
    Time: 8:02:08 PM
    User: N/A
    Computer: GAMER
    Description:
    that you continue.
    Cleaning up 2 unused index entries from index $SII of file 0x9.
    Cleaning up 2 unused index entries from index $SDH of file 0x9.
    Cleaning up 2 unused security descriptors.
    Internal Info:
    57 0d 00 00 00 00 00 00 1b 00 00 00 00 00 00 00 W...............
    7a 4b f2 01 00 00 00 00 08 bd 56 07 00 00 00 00 zK........V.....
    c4 4f 95 01 00 00 00 00 00 00 00 00 00 00 00 00 .O..............
    00 00 00 00 00 00 00 00 f8 a7 76 16 00 00 00 00 ..........v.....
    80 88 65 78 00 00 00 00 b8 3c 07 00 03 15 00 00 ..ex.....<......
    Griffon2-6, Aug 12, 2013
  7. Griffon2-6
    OS should be on C:, this may be one of your problems
    how many drives do you have?
    what partitions on each drive?
    is the date/time correct on your task bar?
    is the date/time correct in the Bios?
    your cmos battery might be failing if the time does not stay correct.
    Elizabeth23, Aug 12, 2013
  8. Griffon2-6
    Griffon2-6
    Hi,
    My OS is on C:. I think for that for some reason the logs for the latest chkdsk operation weren't written.
    I have two harddrives, one 2 Gb drive with one partition and one 250 Gb drive with 4 partitions. The date and time appear to always be correct in the task bar and also in the BIOS. I don't think there's a problem with the CMOS battery.
    Should I run chkdsk again? If so, how can I ensure that the results are logged?
    Griffon2-6, Aug 13, 2013
  9. Griffon2-6
    In Event Viewer, right-click Application in the left pane , then click Properties, then click Restore Defaults and Clear Log on the General tab, and Restore Defaults on the Filter tab, then Apply, OK.
    Have you ever cleared the logs?
    They should over write when full, but go ahead and right click on each, choose clear all events, say no to save you will not need them now.
    and do the above on the filter tab for applications,
    and then run checkdisk again.
    Elizabeth23, Aug 13, 2013
  10. Griffon2-6
  11. Griffon2-6
    Griffon2-6
    Hi,
    That seems to have fixed the Event Viewer. Please find the log for my latest chkdsk run below. Thanks!
    Event ID: 1001
    Date: 8/13/2013
    Time: 9:44:29 PM
    User: N/A
    Computer: GAMER
    Description:
    Checking file system on C:
    Volume label is Roots.
    A disk check has been scheduled.
    The sequence number 0x10 in file 0xf is incorrect.
    Correcting a minor error in file 15.
    The file attributes flag 0x20 in file 0xf is incorrect.
    The expected value is 0x26.
    The attribute list in file 0xf indicates the standard information
    attribute is outside the base file record segment.
    Deleted corrupt attribute list for file 15.
    Deleting orphan file record segment 857.
    Deleting orphan file record segment 974.
    Deleting orphan file record segment 1025.
    Deleting orphan file record segment 1026.
    Deleting orphan file record segment 1027.
    Deleting orphan file record segment 1028.
    Deleting orphan file record segment 1206.
    Deleting orphan file record segment 2659.
    Deleting orphan file record segment 2660.
    Deleting orphan file record segment 2670.
    Deleting orphan file record segment 2671.
    Deleting orphan file record segment 2672.
    Deleting orphan file record segment 2674.
    Deleting orphan file record segment 2678.
    Deleting orphan file record segment 2679.
    Deleting orphan file record segment 2680.
    Deleting orphan file record segment 2684.
    Deleting orphan file record segment 2686.
    Deleting orphan file record segment 2690.
    Deleting orphan file record segment 2691.
    Deleting orphan file record segment 2708.
    Deleting orphan file record segment 2718.
    Deleting orphan file record segment 3056.
    Deleting orphan file record segment 3074.
    Deleting orphan file record segment 3080.
    Deleting orphan file record segment 3097.
    Deleting orphan file record segment 3105.
    Deleting orphan file record segment 3127.
    Deleting orphan file record segment 3143.
    Deleting orphan file record segment 3145.
    Deleting orphan file record segment 3146.
    Deleting orphan file record segment 3148.
    Deleting orphan file record segment 3200.
    Deleting orphan file record segment 3207.
    Deleting orphan file record segment 3279.
    Deleting orphan file record segment 3291.
    Deleting orphan file record segment 3320.
    Deleting orphan file record segment 3348.
    Deleting orphan file record segment 3365.
    Deleting orphan file record segment 3371.
    Deleting orphan file record segment 3374.
    Deleting orphan file record segment 3391.
    Deleting orphan file record segment 3406.
    Deleting orphan file record segment 3438.
    Deleting orphan file record segment 3560.
    Deleting orphan file record segment 3580.
    Deleting orphan file record segment 3711.
    Deleting orphan file record segment 3731.
    Deleting orphan file record segment 3732.
    Deleting orphan file record segment 3733.
    Deleting orphan file record segment 3735.
    Deleting orphan file record segment 3737.
    Deleting orphan file record segment 3772.
    Deleting orphan file record segment 3869.
    Deleting orphan file record segment 3879.
    Deleting orphan file record segment 3880.
    Deleting orphan file record segment 3896.
    Deleting orphan file record segment 4150.
    Deleting orphan file record segment 4240.
    Deleting orphan file record segment 4263.
    Deleting orphan file record segment 4340.
    Deleting orphan file record segment 4365.
    Deleting orphan file record segment 4366.
    Deleting orphan file record segment 4835.
    Deleting orphan file record segment 4928.
    Deleting orphan file record segment 5012.
    Deleting orphan file record segment 5018.
    Deleting orphan file record segment 5114.
    Deleting orphan file record segment 5116.
    Deleting orphan file record segment 5118.
    Deleting orphan file record segment 5600.
    Deleting orphan file record segment 5602.
    Deleting orphan file record segment 8693.
    Deleting orphan file record segment 8744.
    Deleting orphan file record segment 8852.
    Deleting orphan file record segment 9250.
    Deleting orphan file record segment 9438.
    Deleting orphan file record segment 9490.
    Deleting orphan file record segment 9552.
    Deleting orphan file record segment 9710.
    Deleting orphan file record segment 9910.
    Deleting orphan file record segment 10010.
    Deleting orphan file record segment 12034.
    Deleting orphan file record segment 12208.
    Deleting orphan file record segment 14660.
    Deleting orphan file record segment 15078.
    Deleting orphan file record segment 15450.
    Deleting orphan file record segment 15543.
    Deleting orphan file record segment 16652.
    Deleting orphan file record segment 16772.
    Deleting orphan file record segment 18155.
    Deleting orphan file record segment 19387.
    Deleting orphan file record segment 19517.
    Deleting orphan file record segment 19550.
    Deleting orphan file record segment 19637.
    Deleting orphan file record segment 19653.
    The file reference 0x1000000000000f of index entry pagefile.sys of index $I30
    with parent 0x5 is not the same as 0xf00000000000f.
    Deleting index entry pagefile.sys in index $I30 of file 5.
    Cleaning up minor inconsistencies on the drive.
    CHKDSK is recovering lost files.
    Recovering orphaned file pagefile.sys (15) into directory file 5.
    Cleaning up 7270 unused index entries from index $SII of file 0x9.
    Cleaning up 7270 unused index entries from index $SDH of file 0x9.
    Cleaning up 7270 unused security descriptors.
    Inserting data attribute into file 15.
    CHKDSK is verifying file data (stage 4 of 5)...
    File data verification completed.
    CHKDSK is verifying free space (stage 5 of 5)...
    Free space verification is complete.
    CHKDSK discovered free space marked as allocated in the
    master file table (MFT) bitmap.
    CHKDSK discovered free space marked as allocated in the volume bitmap.
    Windows has made corrections to the file system.
    43447760 KB total disk space.
    26581939 KB in 119531 files.
    86056 KB in 14461 indexes.
    583409 KB in use by the system.
    16196356 KB available on disk.
    86895521 total allocation units on disk.
    32392712 allocation units available on disk.
    Internal Info:
    e0 9a 02 00 72 0b 02 00 3c 32 03 00 00 00 00 00 ....r...<2......
    32 fb 00 00 05 00 00 00 1e 28 00 00 00 00 00 00 2........(......
    7e 4b a1 21 00 00 00 00 0e 1d 4e a9 00 00 00 00 ~K.!......N.....
    16 88 f1 dd 00 00 00 00 7c 10 bc 66 05 00 00 00 ........|..f....
    d2 41 e9 01 01 00 00 00 2e e9 78 30 08 00 00 00 .A........x0....
    10 f6 d2 b2 00 00 00 00 d8 3c 07 00 eb d2 01 00 .........<......
    00 00 00 00 00 cc 6e 56 06 00 00 00 7d 38 00 00 ......nV....}8..
    Windows has finished checking your disk.
    Please wait while your computer restarts.
    Cleaning up 4 unused index entries from index $SII of file 0x9.
    Cleaning up 4 unused index entries from index $SDH of file 0x9.
    Cleaning up 4 unused security descriptors.
    26580760 KB in 119506 files.
    86056 KB in 14460 indexes.
    583630 KB in use by the system.
    16197314 KB available on disk.
    32394628 allocation units available on disk.
    Internal Info:
    e0 9a 02 00 58 0b 02 00 29 32 03 00 00 00 00 00 ....X...)2......
    32 fb 00 00 05 00 00 00 bc 0b 00 00 00 00 00 00 2...............
    2a 61 76 21 00 00 00 00 d4 1c a8 a7 00 00 00 00 *av!............
    ee 3c 92 6a 00 00 00 00 76 f2 46 69 05 00 00 00 .<.j....v.Fi....
    e0 68 f0 01 01 00 00 00 7c f4 c7 ba 07 00 00 00 .h......|.......
    30 44 d3 b2 00 00 00 00 d8 3c 07 00 d2 d2 01 00 0D.......<......
    00 00 00 00 00 60 5c 56 06 00 00 00 7c 38 00 00 .....`\V....|8..
    Griffon2-6, Aug 14, 2013
  12. Griffon2-6
    Griffon2-6
    (cont'd)
    Cleaning up 25 unused index entries from index $SII of file 0x9.
    Cleaning up 25 unused index entries from index $SDH of file 0x9.
    Cleaning up 25 unused security descriptors.
    26586987 KB in 119690 files.
    86092 KB in 14474 indexes.
    582848 KB in use by the system.
    16191833 KB available on disk.
    32383667 allocation units available on disk.
    Internal Info:
    e0 9a 02 00 1e 0c 02 00 4a 33 03 00 00 00 00 00 ........J3......
    32 fb 00 00 05 00 00 00 d3 0b 00 00 00 00 00 00 2...............
    52 9f 33 21 00 00 00 00 e6 84 2e a7 00 00 00 00 R.3!............
    06 1d f0 69 00 00 00 00 4c 42 d9 60 05 00 00 00 ...i....LB.`....
    42 a7 53 03 01 00 00 00 44 f0 21 b1 07 00 00 00 B.S.....D.!.....
    f0 a7 d2 b2 00 00 00 00 d8 3c 07 00 8a d3 01 00 .........<......
    00 00 00 00 00 ac bd 56 06 00 00 00 8a 38 00 00 .......V.....8..
    Cleaning up 23 unused index entries from index $SII of file 0x9.
    Cleaning up 23 unused index entries from index $SDH of file 0x9.
    Cleaning up 23 unused security descriptors.
    26682593 KB in 119760 files.
    86172 KB in 14500 indexes.
    581194 KB in use by the system.
    16097800 KB available on disk.
    32195601 allocation units available on disk.
    Internal Info:
    e0 9a 02 00 7e 0c 02 00 b5 33 03 00 00 00 00 00 ....~....3......
    32 fb 00 00 05 00 00 00 d4 0b 00 00 00 00 00 00 2...............
    de 25 7b 21 00 00 00 00 cc 6d 78 a7 00 00 00 00 .%{!.....mx.....
    46 68 3c 6a 00 00 00 00 02 6b 67 62 05 00 00 00 Fh<j.....kgb....
    ee bc 28 03 01 00 00 00 a2 ed 05 b3 07 00 00 00 ..(.............
    f0 a7 d2 b2 00 00 00 00 d8 3c 07 00 d0 d3 01 00 .........<......
    00 00 00 00 00 86 93 5c 06 00 00 00 a4 38 00 00 .......\.....8..
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp
  13. Griffon2-6
    Okay, your checkdisk looks good now, there are always going to be some index things to clear up, but no more errors have been found.
    Run the computer for a while and see if any issues occur.
    has the usb issue resolved itself ?
    Elizabeth23, Aug 14, 2013
  14. Griffon2-6
    Griffon2-6
    Hi,
    The problem doesn't seem to have been fixed. Any other things I can try?
    Thanks.
    Griffon2-6, Aug 18, 2013
  15. Griffon2-6
    http://support.microsoft.com/kb/310575
    troubleshooting usb ports.
    http://support.microsoft.com/kb/817900
    why usbs may quit working.
    when the device manager window opens, scroll down, find universal serial bus controllers
    double click universal serial bus controllers, it's on this list
    now you will see a list, find USB root hub on the list
    double click the first USB hub on the list (or in a laptop check the settings for mouse and keyboard power saving)
    when the USB hub properties window opens, click the power management tab at the top of the window
    now you will see a box that says: "allow computer to turn off this device to save power"
    Un-check that box, click OK
    Now double click the second USB hub on the USB Hub Properties list, click the power management tab, un-check the power saver box just as above and click OK
    Now repeat that same procedure for all the other USB hubs on the list, un-check the power saver box in each USB hub, until you have done all the USB hubs on the list. There may be several, you must do each, one at a time.
    Now close all your windows and restart the computer
    test the device now.
    Also, were there any yellow exclamation points in device manager???
    http://www.usbman.com/WinME USB Guide.htm
    more troubleshooting.
    post back if any of the above helps.
    Elizabeth23, Aug 19, 2013
  16. Griffon2-6
    madcratebuilder
    NW Oregon
    I would use Hard Disk Sentinel or Crystal Disk info and see what's up with your HHD's. Chkdsk doesn't give you much info. HDS is very good and worth buying th epro version. Sometimes doing a format and writing all 1's or 0's to the hhd well recover any bad sectors, or at least reallocate them.
    When I have usb problems it's almost always from buggy drivers, look for the latest available.
    madcratebuilder, Aug 19, 2013
  17. Griffon2-6
    Griffon2-6
    Hi,
    It took a while, but I've tried all of the suggestions above. However, the problem still persists. I've checked Device Manager again and there are no yellow exclamation marks underneath any of the devices listed, even hidden ones.
    Maybe it would serve as a helpful reminder to say again that some devices do still work on the computer, such as the USB keyboard and mouse, as well as those smart cards. Other devices such a storage devices and printers trigger the problem when plugged in. Also keep in mind that this problem does not occur when booted into Linux, which would seem to suggest that hardware is not the problem.
    Also, I don't know if this is relevant or not, but the drivers for the USB smart cards were installed shortly before this problem was noticed. However, uninstalling those drivers and accompanying software did not resolve the problem.
    I would really appreciate any other suggestions you might have.
    Thanks!
    Griffon2-6, Aug 29, 2013
    #17
  18. Griffon2-6
    Some USB2 devices do not work properly on USB 1.1 ports, and some USB1.1 devices fail on USB2 ports. onboard usb cannot provide enough power then you need powered usb hub.
    Format the usb key and see if this solve the problem, also check your security settings to not conflict with inserted usb drives.
    Did the flash drives work okay, and then stopped for no reason?
    1. you might plug in the flash drive, open device manager, go to disk drives and uninstall the flash drive, (leave it plugged in), restart pc and let windows reinstall the driver for the flash drive.
    xxxxxxxxxxxxxxxxxxxxxxxxx
    When you connect a USB drive for the first time the computer will install a driver, that baiscally tells the computer what kind of instructions it needs to carry out in order to talk to your particular brand of USB drive. Sometimes when the drivers are loaded on the computer they are able to cause it to freeze.
    Does the computer just freeze completely or are you able to move the mouse around and click on the start menu with the keyboard? If you can, press CTRL+ALT+DEL at the same time to open Task Manager, and choose the column that says CPU usage. If you can, find the name of the program that has the highest number in CPU usage (apart from System Process). If you can, End that process and it might work.
    did this work?
    1) Insert a USB Cardbus into the Wireless Adapter slot
    2) After computer accept the card
    3) Insert a USB Flash Memory stick into the Cardbus
    4) Once the computer accepts the stick
    5) The regular USB slot will work
    Try it.
    This worked for another user, but I could not verify.
    cccccccccccccccccccc
    Any new errors in event viewer when the freeze occurs?
    1. when a freeze occurs, wait approx 10 -15 minutes, and does it unfreeze?
    post back with results.
    Elizabeth23, Aug 29, 2013
    #18
  19. Griffon2-6
    Griffon2-6
    Hi,
    Thanks for the reply. Yes, the flash drives were all working on this computer for many years and all seem to have inexplicably stopped working. The drives still work fine on other computers. All of the ports on the computer are USB 2.0 ports and all of the devices that we have are also USB 2.0 compliant.
    The computer does freeze completely when a USB drive or pinter is plugged in and the computer becomes inoperable without a hard reset (at which point the USB device needs to be removed, otherwise Windows doesn't even load the login screen). I've tried waiting for around 2 hours but the computer doesn't unfreeze.
    Another thing I've tried is to capture USB packet data on one USB port using USBPcap (an extension for Wireshark) and then plug in a USB drive to that port, but no packets are recorded before the computer freezes. After restarting the computer, checking the log file also yields no packets. I've been able to successfully log packet data from the few devices that do work on this computer though.
    I've also tried showing non-present devices in Device Manager and removing all of the USB Mass Storage Device drivers, then plugging in a USB drive, but the computer freezes like before, without any prompt to install drivers for the device.
    I don't have a USB cardbus to try your last solution with, and no new errors have appeared in the event viewer. I will try this if you feel that it's likely to solve the problem, even given the new information I've provided.
    Thanks again!
    #19
  20. Griffon2-6
    in device manager the flash drive will be listed in Disk Drives,
    with the flash drive plugged in, do not open or anything, go to device manager, look under disk drives, uninstall the flash drive.
    restart pc, and see if windows will load the new driver now.
    what I am thinking is that you may have to copy all data , on the pc that does not freeze, off the flash drive, then reformat, then copy all data back and see if that may be a solution
    #20
