Compaq Evo not working with new hard drive
Discussion in 'Windows XP Hardware' started by racerx2004, Mar 5, 2016.
  1. racerx2004
    racerx2004
    Hello all, im trying to add a seagate hard drive ( 250 GB ) to an old Evo compaq pc wich came with a maxtor 80 GB HD. , I plugged the hard drive (SEAGATE ) and pc recognized it and was fine with it.
    Issues started when i Copied some files to Seagate HD, I was goin to use seagate HD As main disk and leave the 80 GB maxtor for storage.
    I used seagate tools to prep the HD . and when i was ready to clone or copy the OS to seagate thats when issues started.
    When the 2 HD are plugged the pc does not get to log in screen. I keep getting different errors , When the 250 gb is removed the pc works fine.
    Is there something i need to check ?
    I have done the same procedure in the past with an Hp and had no issues.
    Any pointers will be greatly appreciated.
    Specs on the Pc :
    Compaq Evo , Windows XP pro service pack 3 , intel pentium 4 1.50 ghz , 1.5 gb ram , NVIDIA Vanta
    T I A
  2. racerx2004
    Elizabeth23, Mar 5, 2016
  3. racerx2004
    racerx2004
    i ran the numbers thru hp and it says its a EVO D500 MT
  4. racerx2004
    racerx2004
    PROBLEM SOLVED
    It seems I had the jumpers set wrong in the master HD.
    Now seagate hard drive is recognized and working fine.
  5. racerx2004
    Great work! :)
