Changing The "OPEN" Box
Discussion in 'Windows XP Customization' started by cornemuse, May 14, 2020.
  1. cornemuse
    On another computer, the "Open" box changed to:
    (This box along side of in this case PaintDotNet)
    Change back to this:
    (This is the computer I am on-line with right now, same PDN, same "Open" window)
    Notice no icons on the side of this box.
    On the problem computer, the hdd/os started gettin' buggy. I re-installed XP-64 bit & transfered all files etc etc. But, I cannot remember how to change this setting for the life of me.
    Those icons annoy me, thats the main reason for changing it!!
    -corne-
  2. cornemuse
    I believe in folder options you have the choice between "show common tasks" and "use classic folders" have you tried choosing classic folders?
    Elizabeth23, May 14, 2020
  3. cornemuse
    I'll check it out, , , ,
    cornemuse, May 15, 2020
  4. cornemuse
    Didnt work, , , , ,
    cornemuse, May 16, 2020
  5. cornemuse
    Elizabeth23, May 17, 2020
