BSOD at startup Winxp 64 bit
Discussion in 'Windows XP Help and Support' started by black5ent, Mar 18, 2013.
  1. black5ent
    black5ent
    STOP: 0x0000007E (0xFFFFFFFFC0000005,0xFFFFFADF8BFF8B59,0xFFFFFADF90A0E910,0xFFFFFADF90A0E320)
    I am only able to get into safe mode...
  2. black5ent
    http://support.microsoft.com/kb/330182
    read this and give the rest of the error message, so we can find out which driver is causing the problem.
    then I want you to run the recovery console, it is better to do it outside the windows environment, but it can be done within
    go to start, run, type in cmd
    in cmd prompt type in chkdsk c: /r and press enter
    type Y for yes press enter
    type exit, press enter, restart pc, and let finish, this can be a lengthy process depending on the size of the harddrive
    if any errors are found, run again until no errors are found
    view report by going to start, control panel, administrative tools, event viewer, applications, winlogon.
    below are instructions to burn a Hiren's boot cd from a working pc, and ensure it is bootable.
    Courtesy of Jose Ibarra:
    http://www.hirensbootcd.org/download/ (look near the bottom of the page, do not click on any ads).
    http://www.hirensbootcd.org/burning/
    Instructions
    http://rufus.akeo.ie/
    Elizabeth23, Mar 18, 2013
  3. black5ent
    black5ent
    BSOD at startup WinXP 64
    this is the only info on the screen...
    STOP: 0x0000007E (0xFFFFFFFFC0000005,0xFFFFFADF8BFF8B59,0xFFFFFADF9 0A0E910,0xFFFFFADF90A0E320)
    I have booted to the Mini XP desktop. Attached is the chkdsk report
  4. black5ent
    you want to run with the /r parameter
    chkdsk c: /r there will be five stages.
    if you are doing this through windows, error checking, then check both boxes here
    go to my computer, right click on local disk and choose properties, choose tools, choose error checking.
  5. black5ent
    did you install anything or remove anything prior to this error?
  6. black5ent
    black5ent
    I will run chkdsk now as described. I did not install or remove anything from the computer.
  7. black5ent
    black5ent
    Should I do this in Safe mode or mini xp?
  8. black5ent
    either, if you run through Hiren's the message will stay on the screen
    if you run through windows, you will have to look in event viewer, as described earlier.
    Also look in device manager for any warnings. ( right click my computer in safe mode, choose manage, choose device manager.)
  9. black5ent
    black5ent
    There are no warnings in the device manager... I am waiting for the 5 stages to complete... Currently half way through phase 4
    black5ent, Mar 19, 2013
  10. black5ent
    black5ent
    What are the next steps after "Phase 5" completes?
  11. black5ent
    if checkdisk finds and fixes any errors, then run again until no errors are found.
    do not worry about security discriptors, just see if any errors are found.
    -----------------once check disk is clean
    try to boot normally, What happens? if you can see what says is causing the issue, if you still get a blue screen, 7E is a driver issue
    Elizabeth23, Mar 19, 2013
  12. black5ent
  13. black5ent
    black5ent
    BSOD winxp 64
    The 5 phases of error checking have completed. The system still has the same issue. Still goes to blue screen on startup.
  14. black5ent
    black5ent
    I will go to the google article now
  15. black5ent
    do a clean boot
    http://support.microsoft.com/kb/310353
    this will tell us if it is a start up program that is causing the blue screen.
    do not bother with the guided help, most of the time it will not install, just go straight to method 2.
