Avast Oddity
Discussion in 'Windows XP Security' started by Termingamer2-JD, Sep 22, 2015.
  1. Termingamer2-JD
    Termingamer2-JD
    England
    Hi.
    I uninstalled Avast long ago, however Security Centre seems to think I still have it installed.
    I have tried to delete every instance of 'Avast' from the registry, but it still appears. I think I found the key to delete 'LEGACY_AVAST_ANTIVIRUS' but it doesn't let me delete this particular key or edit it.
    It's not that much of an issue, as it doesn't appear if MSE is up to date, but I don't know why Avast is still viewed by the security centre.
  2. Termingamer2-JD
    to delete a registry key:
    right click on desired key
    choose permissions
    choose everyone
    click ok then you can delete key
    Ensure you are deleting the right key !!!!
    I have noticed that a lot of antivirus do not want you to delete their registry keys, this is probably due to self protection so that a malware cannot delete the keys or change them :)
    Elizabeth23, Sep 22, 2015
