Android Emulator for XP
Discussion in 'Windows XP Games' started by Dejan97, Mar 4, 2018.
  1. Dejan97
    Dejan97
    Is there any Android Emulator that can be used on Windows XP???
    Spec 1GB RAM
    AMD Athlon 64 3000+
    Nvidia GeForce 7300LE
  2. Dejan97
    Elizabeth23, Mar 4, 2018
  3. Dejan97
    Dejan97
    Dejan97, Mar 5, 2018
  4. Dejan97
    okay, maybe someone else has a good program for you.
    Elizabeth23, Mar 5, 2018
  5. Dejan97
    lmemsm
    If you can run Virtualbox (or perhaps qemu) on your system, you can run Android-X86 in it.
    lmemsm, May 15, 2020
  6. Dejan97
    Oef564
    Oef564, Mar 15, 2021
  7. Dejan97
    I wouldn't waste my time with Android x86. Oh wait, I did, that's why I'm telling you not to bother. The problem is the vast majority of android apps require ARM CPU and are incompatible with x86 CPUs. The core Google apps have x86 versions (GMail, Youtube, Play Store etc.) as does Firefox but practically every app I tried wouldn't work/force closed. Android x86 is a novelty.
    I've never tried any of the Android emulators so can't comment.
    ClippyBeer, Mar 15, 2021
  8. Dejan97
    red Guest
    phoenix os works on most pc make sure you get the correct version ie 32 or 64 bit works on play store :)
    have it on old dell along with win 7 64 bit best of both worlds :)
    long live xp
    red, Jul 22, 2021
