adobe flash and other .exe download wont open
Discussion in 'Windows XP Help and Support' started by rocker2541, May 26, 2015.
  1. rocker2541
    rocker2541
    Hello all. On here for support if possible. I just reloaded windows XP service pack 2 with no problem on my desktop. Downloaded AVG for antivirus and also firefox browser. Adobe's exe file will open for installation, but then gives a connection error which I am lost with. Also some executables just will not open after downloaded. Example being the WLC player...It downloads, but when clicking on it to open, it does nothing.
  2. rocker2541
    do you have a 64 bit system??
    if not then you need to download and install sp3 and all the updates from microsoft updates.:
    Courtesy of Tricky 300
    Before you install SP3 read this article…
    http://support.microsoft.com/kb/950717
    …and if your PC is an HP Pavilion, Presario or Media Center and has an AMD processor you need to install this patch before installing SP3…
    http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=uk&lc=en&dlc=en&softwareitem=pv-60484-2
    …to find out if you have an AMD processor...
    • Hold down the Windows key (between Ctrl and Alt) and hit the Pause Break key
    • Your processor type is shown in the Computer: section
    Then install SP3 by downloading and running from...
    http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=24
    …you can ignore the text that says that it is for network installations and also ignore the text advising Windows/Microsoft Update if only updating one PC.
    Reboot twice after installing.
    Elizabeth23, May 27, 2015
  3. rocker2541
    Elizabeth23, Feb 17, 2016
