Add/Remove Programs won't populate completely
Discussion in 'Windows XP Help and Support' started by Greekdrama, Jan 13, 2014.
  1. Greekdrama
    Greekdrama
    Had a virus and a trojan which I've finally cleaned out, but now my Add/Remove Programs screen will only populate partially. Any help in getting it back?
    Thanks!
  2. Greekdrama
    first run checkdisk:
    go to start, run, type in cmd
    type exit and press enter
    you can see report in event viewer/applications/winlogon
    report back after running checkdisk until there are no more errors found and we can troubleshoot further.
    Elizabeth23, Jan 13, 2014
