64 bit xp
Discussion in 'Windows XP Installation and Setup' started by red, May 4, 2021.
  1. red
    red Guest
    just be given 2 old dell inspiron made a good 1 out of the 2 but now stuck ,my copies of xp are all for 32 bit and laptops are 64bit so do i need a 64 bit version of xp ? or is there a trick to get mine to install
    ty :)
    ok so stupid question ;( just got xp64bit so trying it now came with key so not so bad:)
    red, May 4, 2021
  2. red
    Elizabeth23, May 4, 2021
  3. red
    red Guest
    ty :)
    red, May 4, 2021
  4. red
    Samir
    HSV and SFO
    Very easy to do. I've done this many times. Switch the bios to legacy and just install away. While it's installing, go download all the xp drivers for the hardware. Once it is up, copy the drivers to the new system using a usb drive and then load in the drivers. Reboot as needed and you're done!
    Samir, May 30, 2021
  5. red
    red Guest
    red, Aug 9, 2021
    Samir likes this.
  6. red
    Samir
    HSV and SFO
    Samir, Aug 9, 2021
  7. red
    red Guest
    no just downloaded and run had to update a few drivers which you get from dell
    red, Aug 9, 2021
  8. red
    Samir
    HSV and SFO
    Sweet. Several of my systems can handle much more ram, so this might be the way to go on them if timefreez or reboot restore work with them and some portable browser is available that's decently modern.
    Samir, Aug 10, 2021
    cartpusher54 likes this.
  9. red
    cartpusher54
    I use mypal and 360chrome on my xp 64 bit. I have an i7 2600 with 8 gigs of ram and ssd so its really fast.
    cartpusher54, Aug 31, 2021
    Samir likes this.
  10. red
    Samir
    HSV and SFO
    Great to hear! Have you tried portable chrome 64-bit? I don't trust the 360chrome. Here's a link to it if you want to try it:
    https://sourceforge.net/projects/wi...ses/X-Chromium_68.0.3407.0_rev16.zip/download
    If this works, then I think I'll try xp 64-bit on my i7-2600 too. :)
    Samir, Aug 31, 2021
  11. red
    cartpusher54
    No I get the procedure entry point not found message. Which is what I was expecting however I bet it works with vista if you have its extended kernel.
