1 gb memory only or 1 gb and 256 mb together?
Discussion in 'Windows XP Help and Support' started by dksellou, Jun 22, 2015.
  1. dksellou
    dksellou
    Hi, I replaced one of my 256 MB of memory in my Dell dimension 3000 with 1 GB. Is it better to remove the other 256 MB as well and leave only the 1GB or keep them both?
    If I remember correctly in a mac they recommend putting the same amount of memory in pairs...
    Please advice and thanks
  2. dksellou
    Rhino Cracker
    equal pairs are needed to use dual channel (like raid 0 access to your ram)
    Rhino Cracker, Jun 22, 2015
  3. dksellou
    dksellou
    Thank you!
    But i dont think you can put 2 gb in a dell dimension so i will leave blank the one slot?
    Is it better?
  4. dksellou
    I have 2ea, 1gb sticks for a total of 2gb. It is possible to get up to 4gb in xp on a 32bit system.
    Elizabeth23, Jun 23, 2015
  5. dksellou
    dksellou
    i don't plan to buy more memory.
    is it better then i slot with 1 gb, or 2 slots 1 gb and 256 mbs?
    dksellou, Jun 23, 2015
  6. dksellou
    Rhino Cracker
    1280MB should be better - as long as one of them isn't incredibly slow.
    Afaik your memory clock will be set by the slowest ram, this means: if your 1gb stick can handle 1000MHz and your 256mb stick can only handle 400MHz, both sticks will run at 400MHz.
    Rhino Cracker, Jun 23, 2015
  7. dksellou
    above from here
    you can read more from dell on the search page here
    but to answer your question, I would just go with the one stick of 1gb and leave out the 256 stick. :)
  8. dksellou
    dksellou
    Thank you all
    I will go with what you said Elizabeth!
    dksellou, Jun 24, 2015
  9. dksellou
    okey dokey. :)
    Elizabeth23, Jun 24, 2015
