Windows XP Forums
Reply
Thread Tools Display Modes
Someting on this Laptop is blocking power to the PCMCIA slot, HELP!
Kelvin
Guest
Posts: n/a
      28th April 2010
I have three laptops what have about the same issue.
We use Verizon Air Cards that use the PCMCIA slot. Verizon card model number
PC770 if it matters.
I had a Dell laptop that was doing this and Dell ended up replacing the
mother board as it seemed it was a hardware issue.
With the new mother board in there was still no power (no lights on on the
card) to the card.
Ended up deleting the partition and reinstalling XP.
The card now works.
Did the same to a Dell PC Monday. Reinstalled XP from scratch, cards works.
I have a Panasonic Toughbook I'm having the same issue with.
I really don't want to have to reinstall the OS as it's has a number of
specialty apps our mechanics use, and I have to send it off to be reimages
as a result. I don't have access to the apps...
Anyone run across this issue and found a solution?
Anyone have any idea how to get this resolved?
I can take a known good card and put it in my laptop and it works, put it in
the laptop in questions, doesn't work.
Take the card that the user had been using and put it in my laptop and it
works.
Very frustrating.
Any help would be much appreciated!
Kelvin
David H. Lipman
Guest
Posts: n/a
      28th April 2010
| card) to the card.
| The card now works.
| works.
| Very frustrating.
| Kelvin
What model laptop is this happening in presently and in the past ?
Dave
http://www.claymania.com/removal-trojan-adware.html
Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp
Lem
Guest
Posts: n/a
      28th April 2010
> card) to the card.
> The card now works.
> works.
> Very frustrating.
> Kelvin
You're only assuming that because there are no lights on the card that
the is no power being supplied. Because it doesn't, in fact, seem to be
a hardware problem, perhaps there is a conflict that corrupts the driver
when you attempt to install it. Try using msconfig to disable all non-MS
apps and services and then install the card. Don't forget to clean up
remnants of previous install attempts. See this thread:
http://businessforums.verizon.net/t5...highlight/true
Another place to start would be to consider how the new installs of XP
differed from what was on the laptops previously. In other words, on the
the two Dells, did you install from a vanilla XP CD or from a Dell
restore CD. Assuming the former, what Dell software was installed but
now isn't there?
The fact that the same issue is happening with a Panasonic Toughbook
might actually help eliminate issues: what software is on both the
Toughbook and the Dells prior to the clean XP install?
Lem
Apollo 11 - 40 years ago:
http://www.nasa.gov/mission_pages/ap...0th/index.html
John Wunderlich
Guest
Posts: n/a
      28th April 2010
"Kelvin" <(E-Mail Removed)> wrote in
news:#(E-Mail Removed):
> model number PC770 if it matters.
> replacing the mother board as it seemed it was a hardware issue.
> on on the card) to the card.
> The card now works.
> cards works.
> number of specialty apps our mechanics use, and I have to send it
> off to be reimages as a result. I don't have access to the apps...
> put it in the laptop in questions, doesn't work.
> and it works.
> Very frustrating.
> Kelvin
It could be a driver issue.
Start up Device Manager:
Start->Run->"devmgmt.msc"
Look for your device and make sure there is no errors or warnings on
the device. Record the driver version and date. Then go to the
manufacturer's website and see if there is a newer driver.
HTH,
John
Kelvin
Guest
Posts: n/a
      28th April 2010
A Dell Latitude D630, a Dell Latitude E6500 and the Panasonic Toughbook
CF-52.
All have been running fine for months.
"David H. Lipman" <DLipman~nospam~@Verizon.Net> wrote in message
news:%(E-Mail Removed)...
> From: "Kelvin" <(E-Mail Removed)>
> number
> the
> | card) to the card.
> | The card now works.
> works.
> reimages
> it in
> it
> | works.
> | Very frustrating.
> | Kelvin
> Dave
David H. Lipman
Guest
Posts: n/a
      28th April 2010
| CF-52.
I knew it !
I too have had several Latitude D630 notebooks loose the ability to communicate with
PCMCIA cards including a Verizon AirCard. I wouldn't categorize it as a power issue. I
categorized it as a failure of any PCMCIA card from performing a Plug 'n Play operation
when inserted within the notebook.
In one case it happened twice to one of my users using his D630 and a Verizon AirCard. It
turned out to be an engineering problem with the PCMCIA cage that situates the PCMCIA
interface to the NB's motherboard. There is too much of a gap and will disconnect from
the motherboard. The engineering fix is a rubber pad that goes between the cage and the
chassis to fill the gap void and prevent the disconnection.
There is an aftermarket engineering fix for this for the Dell Latitude D630. I don't know
about the problem with CF-52 ToughBook. We use them too but for different reasons.
Personally, I like the US made Dell ruggetized notebooks.
BTW: There is also a well known, and documented, defect with the NVidia video chipset on
the D630.
Dave
Pavel A.
Guest
Posts: n/a
      28th April 2010
Maybe all these laptops have been preinstalled with a wrong driver for the
PCMCIA controller.
When you installed XP yourself, it properly detected the controller
and installed the right driver.
If you wish to follow on this issue with Dell or Panasonic, their support
should be able to verify this guess.
--pa
"Kelvin" <(E-Mail Removed)> wrote in message
news:#(E-Mail Removed)...
> card) to the card.
> The card now works.
> works.
> works.
> Very frustrating.
> Kelvin
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
D-link PCMCIA card on a laptop PROBLEMS Kenny S Windows XP Networking 3 1st July 2004 01:17 PM
PCMCIA card crashes laptop Dutchtreat Windows XP Hardware 1 8th December 2003 04:34 PM
High CPU Utilization Coping to a CF Card in a PCMCIA slot VDC Windows XP Hardware 2 18th November 2003 11:33 AM
SRAM card drivers for PCMCIA slot JohnJ Windows XP Hardware 1 24th October 2003 10:15 PM
XPe boot from bootable PCMCIA slot? Huang Sheng-Chi Windows XP Embedded 1 4th August 2003 10:22 PM
Windows XP Forums is an independent website and is not affiliated with Microsoft Corporation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
