What browser will xp users switch to when firefox ends support for xp?
Discussion in 'Windows XP General Discussion' started by Skeleton11223, Feb 20, 2017.
  1. Just wondering if you guys know any good browsers.
  2. Also, does anyone know exactly when firefox is ending support?
  3. Skeleton11223
    tienkhoanguyen
    For Windows XP I use FireFox.
    tienkhoanguyen, Feb 20, 2017
  4. Skeleton11223
    https://blog.mozilla.org/futurereleases/2016/12/23/firefox-support-for-xp-and-vista/
    after september 2017, xp users will be moved to firefox extended support release, see the link below:
    and below is pale moon atom version for xp, but that also is going to be unsupported:
    https://www.palemoon.org/palemoon-atom.shtml
    read below for some other alternative browsers, I am going to check out some of them myself and will post my results in this thread. :)
    Elizabeth23, Feb 21, 2017
  5. Skeleton11223
    Jody Thornton
    Richmond Hill, Ontario
    Jody Thornton, Feb 21, 2017
  6. Skeleton11223
    Jody Thornton
    Just to repeat here, these are the current browsers that are known working:
    SeaMonkey v2.46
    Firefox v51.x
    Cyberfox v51.x (although not officially supported, it fully works)
    Midori v0.5.11
    Maxthon Cloud Browser v5
    Lunascape v6.15
    Dooble v1.56c
    Avant Browser 2016 (**** just don't use Trident ****)
    QupZilla v2.0.1 (the last release was six months ago - so try to confirm if this is currently active)
    For those wanting a native browser for Windows XP x64 Edition, Waterfox (which claims compatibility) hasn't run properly since v46.x, so that may now be a dud. :(
  7. Skeleton11223
  8. Skeleton11223
    priscus
    Interesting looking site: I shall bookmark that one.
    Are the older versions of the mainstream browsers that are no longer supported still usable? (At your own risk basis)
    Be helpful if users will share their experience of the browsers listed.
    priscus, Feb 21, 2017
  9. Skeleton11223
    Ya' all know, you dont have to use the newest versions of anything, including browsers.
    I'm using Firefox Portable 29.0.x, works fine. Tried newer versions, different browsers, prefer this, , ,
    The new versions merely help get the advertisements 'in your face', far as I can tell, , , ,
    cornemuse, Feb 21, 2017
  10. Skeleton11223
    @cornemuse, how do you run a portable, can you still have bookmarks and your own homepage and install addons ??
  11. Using an unsupported OS and browser would be pretty unsafe, I would rather just use one vulnerable thing than two vulnerable things.
    Also, I'd say the best replacement browser is probably opera 36, you don't need many features in a browser, security updates are enough.
    Skeleton11223, Feb 22, 2017
  12. Skeleton11223
    Liz,yes you have your bookmarks, homepage etc etc. It works exactly like a regular installation, except it does not modify/change your registry. And you install it where-ever you want. (actually, it installs where the install exe file is, unless you want it somewhere else. I created 'c:\firefox' on my comp & installed it there)
    A friend (84 yrs old!) really messed up his computer, inc firefox <- would not uninstall/re-install/not work, etc, he was using IE & hating it. I tried FFport & it worked fine right off the bat.
    Save your old bookmarks as html file & paste/copy it to where-ever this new FFportable is, open it & bookmark it. [I end up with 100's of links, way too many!!] Open these links & then bookmark the ones you want to keep. Only thing is, you have to initally enter p/w's from those links needing them, but FFport will remember them if you want, "just like the old browser"
    -corne-
    cornemuse, Feb 22, 2017
  13. Skeleton11223
    j896
    USA
    I am using flash peak slimjet witch is based on chromium, It still geting some updates for XP. (for now any way)
    j896, Feb 22, 2017
  14. Skeleton11223
    @cornemuse, well I am now running the portable version and the first thing that came up before I got a chance to unclick the automatic update, I got a notice that I was using an outdated browser, but I set to not check for updates.
    only one other issue, is it will not remember passwords for some sites, even though the later editions of firefox would save these passwords???
    any ideas?
    Elizabeth23, Feb 22, 2017
  15. Skeleton11223
    reply 2
    @cornemuse: I went back to firefox 51 as could not watch some videos on facebook and the passwords not being saved. :)
    Elizabeth23, Feb 23, 2017
  16. Skeleton11223
    Liz: the newest version of FFPortable?? (I just happen to prefer v. 29.xx portable)
    -c-
    cornemuse, Feb 23, 2017
  17. Skeleton11223
    I see, then I will try the newest version of portable ff, I just tried the version 29 as that was what you used. will get back to you via PM. :)
    #17
  18. Skeleton11223
    Mike_Walsh
    King's Lynn, UK.
    Liz, there's a whole bunch of 'portables', here:-
    www.portableapps.com/apps
    .....in the 'Internet' section.
    I tend to favour the Chromium-based ones myself, having used Chrome since day 1, when it was released back in 2008. SlimJet and SRWare Iron both do portables; SlimJet only up to version 10, Iron still currently supporting XP.
    There's also Chromium-portable, from
    https://sourceforge.net/projects/crportable/files/
    Version 49 still works perfectly well, and is quite safe to use. It's the last version to support XP.
    With the portables, everything is contained within the one folder; bookmarks, extensions, the lot. Which is why you can copy the entire folder from one machine to another. All you need is to use the launcher, within the app folder, to start it.
    All down to personal choice, really. I tend to agree with cornemuse; you don't need to run the 'latest & greatest' browsers all the time. I run 'Puppy' Linux most of the time now; although I package the 64-bit versions of Chrome for the community, and I'm currently 'beta-testing' Chrome 57, my personal 'fall-back' favourite is an elderly version of Chromium; 36.0.1985.143.....because it just 'works'. All the time.
    I find that the best browsers for XP tend to be those that were around when it was still 'current'.
    Mike. ;)
    Mike_Walsh, Feb 23, 2017
    #18
  19. Skeleton11223
    thanks Mike, I will take your suggestions under consideration. :)
    Elizabeth23, Feb 24, 2017
    #19
  20. Skeleton11223
    Jody Thornton
    Well the 52 ESR release came out this week, and XP and Vista users are shifted to the ESR release. So it's probably your BEST best until September. @cornermuse, the only ads you get are in the new tab page. Just delete them and the issues are gone. I think Cyberfox and Waterfox v52 ESR will also work (even in not officially supported), and without any telemetry. Cyberfox is biting the dust as of the end of the ESR cycle. But that's OK because Firefox will too.
    It's safe to say that as of the first quarter of 2018, there will be no current browsers for XP left. You could use a recent one until you ditch the OS in 2019. Then you can look at your platform migration options (which is really what an XP forum should be about in 2017 I'm afraid - "what is the best method of replacing XP".) Taking the approach of "You'll have to pry XP out of my cold, dead hands" is not one you should bet on.
    Jody Thornton, Mar 12, 2017
    #20
