On Sat, 3 May 2008 13:34:00 -0700, carlaz
<(E-Mail Removed)> wrote:
> I see that my computer has only 5% of its
> memory available, do it need to add more RAM?
That does not indicate any sort of problem at all. Wanting to minimize
the amount of memory Windows uses is a counterproductive desire.
Windows is designed to use all, or most, of your memory, all the time,
and that's good not bad. Free memory is wasted memory. You paid for it
all and shouldn't want to see any of it wasted.
Windows works hard to find a use for all the memory you have all the
time. For example if your apps don't need some of it, it will use that
part for caching, then give it back when your apps later need it. In
this way Windows keeps all (or almost all) of your memory working for
you all the time.
Ken Blake, Microsoft MVP - Windows Desktop Experience
Please Reply to the Newsgroup
