Windows XP Forums
Reply
Thread Tools Display Modes
Flight Simulator X MSXML 4 SP2 Problem
Mike
Guest
Posts: n/a
      11th March 2007
Dear Support,
I'm having serious problems installing Flight Simulator X on my fully
updated XP Pro SP2 workstation.
Flight Simulator X fails to put SimConnect.cat, SimConnect.dll and
SimConnect.Manifest in the "C:\Windows\WinSxS" and "Manifests" directories,
however searching the web many, many users are having the same problem.
Thankfully, I have now fixed this problem and setup completes successfully.
When I try to run the Flight Simulator X shortcut on my desktop, I now
receive the following message:
"The MSXML4 SP2 component is not installed. Please reinstall Flight
Simulator to restore or repair this missing component".
I have tried this and it doesn't help. I have also tried manually running
the "msxml.msi" file on Disk 2, however this makes no difference. Browsing to
my C:\Windows\System32 directory, and viewing properties of the msxml4.dll
file shows version: 4.20.9841.0 so it is definitely installed.
My Windows installation itself is about one month old and all other
applications work correctly. I have also disabled unecessary startup
items/services through msconfig and this also makes no difference. I'd
appreciate if someone could shine some light on this problem, as I am at a
loss as to the root of the problem.
TIA
Michael
Jimmy S.
Guest
Posts: n/a
      11th March 2007
Hi Mike,
Try installing MS XML SP2 directly from Microsoft:
http://www.microsoft.com/downloads/d...DisplayLang=en
Before you install it however, you might want to check
your add-remove programs menu to uninstall any previous
version(s) which may cause or be causing this conflict.
Cheers, *Windows_XP_MVP_Shell/User*
Jimmy S. http://mvp.support.microsoft.com
Visit my MSN Games and Windows Gaming Help Site: www.msce.mvps.org
MS Games Help and Support Center: http://support.microsoft.com/?pr=gms
My advice is donated "AS IS" without warranty; nor do I confer any rights.
__________________________________________________ _______
Mike Wrote:
| Dear Support,
| TIA
| Michael
Mike
Guest
Posts: n/a
      11th March 2007
Thanks for the reply Jimmy.
I have already tried this and it didn't fix the problem either. Any other
ideas?
Thanks!
"Jimmy S." wrote:
> Hi Mike,
> Mike Wrote:
> | Dear Support,
> | TIA
> | Michael
Jimmy S.
Guest
Posts: n/a
      13th March 2007
Hi Mike,
Your best solution would be to repair Windows using these instructions:
How to repair Windows XP:
Unplug from your Internet connection, and then repair Windows:
using this method: http://michaelstevenstech.com/XPrepairinstall.htm
Afterwards, boot up your system, turn on your XP Internet Firewall,
plug back into your Internet connection and install all Critical and
Recommended updates from: http://windowsupdate.microsoft.com
| ideas?
| Thanks!
| "Jimmy S." wrote:
|| Hi Mike,
|| Mike Wrote:
||| Dear Support,
||| TIA
||| Michael
david knapp
Guest
Posts: n/a
      16th May 2007
I am getting the same error message. Did you get your FSX to work? If so,
how? I am running XP Home SP2. I have MSXML 4 SP2 (KB927978), MSXML 4 SP2
Parser and SDK, and MSXML 6 installed.
mazituBR
Guest
Posts: n/a
      27th December 2007
I am brazilian and my english isn't very good, but I will try to explay
the things that have to be made! It's very easy!
1-Download this file:
http://www.mediafire.com/?2t1jbgmlrbz
2-Save it to the game's folder (C:\Program Files\Microsof
Games\Microsoft Flight Simulator X).
3-There is already a file with this name so delete it befor
downloading it to the game's folder.
If your problem was not solved, download this file:
http://download.microsoft.com/downlo...N-US/msxml4.EX
and install it.
If you have some questions, just post it here!
I think have helped, Sorry for my English
mazituB
mazituBR's Profile: http://forums.techarena.in/member.php?userid=3825
View this thread: http://forums.techarena.in/showthread.php?t=70292
lowrunner
Guest
Posts: n/a
      3rd March 2009
Will this work with my problem before i start downloading stuff? m
simular problem is: I have recently reformatted my computer, my O.S. i
XP-PRO, SP3 Corporate Edition w/updates, kaspersky internet securit
2009,intel pentiun4 3ghz
im trying to install a downloaded version of "microsoft Fligh
Simulator X" (Razor 1911), but near the end i get this message
("TheMSXML4 SP2 component is not installed,please reinstall Flight Sim
to restor or repair this missing component")
ive tried downloading "MSXML4 SP2" from microsoft but to no avail.
tried downloadin
"msxml4.manifest" and putting into folder,tried downloading sp1 updat
from sim site, but still no luck still get message. have uninstalled an
re-installed around 5 times, each time running Ccleaner to clea
registry and "reg scrub xp", then defrag system before each install
could someone please give me some directions on how to get this fixe
please
i had no problem when my operating system was only updated with sp2
very frustrated please help
thanks for your tim
ps already previously downloaded both of those files. still dont work
everything on my computer works flawlessly except this
lowrunne
lowrunner's Profile: http://forums.techarena.in/members/lowrunner.ht
View this thread: http://forums.techarena.in/windows-xp-games/702928.ht
FlyByNite
Guest
Posts: n/a
      14th June 2009
I just got this working so I'm gonna post what I hope is the definitive
solution to the MSXML4 issue.
I tried pasting someone else's msxml4.manifest into a new text file but
that didn't work. I'm not sure why but the best solution seems to be:
1. Install and patch as normal. Confirm that you still have the "The
MSXML4 SP2 component is not installed. Please reinstall Flight Simulator
to restore or repair this missing component" error.
2. Locate the msxml4.manifest file and rename it to msxml4.manifest.bak
or something like that. If your issue is like mine, this file is over
300k and full of binary junk. The good version should be tiny and have
just a few lines of xml.
2. Download and install the FSX demo from Microsoft.
3. Confirm that the demo works fine on your computer.
4. Locate the msxml4.manifest file in your FSX Demo directory. Note
that this file is about 1k and opening it up in a text editor shows a
few lines of xml.
5. Copy/paste the msxml.manifest file to your full version directory.
6. Click and enjoy.
FlyByNite
FlyByNite's Profile: http://forums.techarena.in/members/105809.htm
View this thread: http://forums.techarena.in/windows-xp-games/702928.htm
yia_tse1
Guest
Posts: n/a
      17th August 2009
Hello...after 3 months of searching i think i have the solution for
msxml4 and flight simulator x fsx.
First of all you don't have to download anything from microsoft or
anywhere and you don't have to change anything about
msxml4.manifest...everything you need is on fsx installation dvd...
The problem is that fsx needs the version 4.20.9818 of msxml4.dll which
is an old version considering that the game is 2-3 years old...So if you
have a newer version of this file e.g. 4.20.9854,4.30.1000...etc and
generally every version above 4.20.9818 that's the problem!!!
When you install fsx on your pc,fsx also tries to install the correct
version of msxml4.But as soon as you have a newer version of msxml4
nothing is installed...So when you try to run fsx it finds a newer
version of msxml4 and gives you the error that msxml4 component is not
install...etc which is really installed but not the specific version
that fsx needs.
The solution is to locate the file msxml4.dll in your hard
disk(c:\windows\system32) and check the version that you have...(if you
have problem with fsx i'm sure that you will have a version above
4.20.9818...)
Move this file to your desktop,or just rename it.Go to control
panel-add/remove programs and remove msxml4.Then go to the fsx dvd and
find and run "msml.msi".Restart your pc and run the game....
If the problem is still there go to c:\windows\system32 and also remove
or rename the files msxml4a.dll and msxml4r.dll.Install msxml.msi from
fsx dvd again and restart your pc again.Run the game and everything
should be ok...The version of these 2 files that i have and the game
works is 4.10.9404
That's all....and congratulations to microsoft who made a game that
works only with a specific old version of msxml4 and not with newer
versions...It is stupid but that's microsoft!!!!
I hope i solve your problem or at least i made you to understand it....
Enjoy the game....
yia_tse1
yia_tse1's Profile: http://forums.techarena.in/members/125806.htm
bob37a
Guest
Posts: n/a
      6th October 2009
> works is 4.10.9404
> Enjoy the game....
Thanks. It doesn't work for me.
The only change I have is that I don't have the msxmla.dll - at all
Any idea why don't I have it
bob37
bob37a's Profile: http://forums.techarena.in/members/141677.ht
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Flight Simulator X ATC voice problem. Watki Windows XP Games 1 15th December 2006 05:00 AM
Flight Simulator 2002: Multi Monitor problem suddste223 Windows XP Games 11 16th September 2006 04:41 AM
Flight Simulator 2004 Installation problem Mariah12547 Windows XP Games 4 17th September 2004 10:47 AM
Problem with my Microsoft 2004 Flight Simulator jay Windows XP Games 3 9th September 2003 02:15 AM
Windows XP Forums is an independent website and is not affiliated with Microsoft Corporation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
